Ignition won't turn back after new parts
Masziviot
Missouri
C30
I have a 78 c30 and when I got it the ignition was stuck on the on position and wouldn't go back any. The truck would still start though. I put a new ignition switch and ignition lock cylinder, but I still am having the problem haven't fully reassembled the steering column yet because I'm still trying to find the issue. I tore or down to the gear and spring to try to find the issue but couldn't find the problem still.
350 w/203
Tilt or non-tilt?
Likely just the switch at the bottom of the column is out of adjustment.
Masziviot
Missouri
C30
Tilt or non-tilt?
Tilt, I tried with out the ignition switched hooked up and still couldn't get it to turn back.
Vic85K10
Colorado Springs
Victor
First time posting but I went through this similar situation about a month ago.
Have you torn down the column far enough to view the sector gear and ignition rack? Does the ignition rack move when you turn the cylinder with the key?
On mine I wasn't able to start the truck because the ignition rack had broken into three pieces. Just my 2 cents.
Masziviot
Missouri
C30
I have it torn down to the little black gear that gets turned by the ignition lock cylinder and it all looks fine there but didn't tear it down any further because don't have the tool to take out the threaded pins
350 w/203
It's about a $7 tool and very handy. Made by Lisle.
Vic85K10
Colorado Springs
Victor
Alrighty, when you turn the cylinder lock can you see the ignition rack move, along with the rod that goes down to the ignition switch? If the rod doesn't move with the key its likely the ignition rack that's broken.
Masziviot
Missouri
C30
The rod does move
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
put a screw in the pin leave enough sticking up to get ahold of it with a pair of needle nose pliers. the pry out on the pin it will come out without special tools...
Vic85K10
Colorado Springs
Victor
Grab that tool or do what C10MixMaster said to tear the column down more so you can get better visuals on it.
In my case the rack would still push the rod every now and then to start the truck until it finally gave out and felt like the cylinder lock was broken.
Best of luck!
Masziviot
Missouri
C30
Okay, thanks for the help after I got home, I tore it down the rest of the way to get a full look. The ignition rack was twisted and the rod was slightly bent so when I have the money I'm ordering the rebulld kit with bearings and also ordering a rod.
Masziviot
Missouri
C30
I have the steering column tore down and ordered the ignition rack and the bearings. The bearing races were gone I just don't know where the lower bearing race goes because when I pulled the rest down to the ignition rack it fell apart and I didn't get to see where it actually goes.
ESONE
