hatzie
- Dec 6, 2011
- NH
- David
- k20
As long as your 1991 is an RV chassis.So, I've been trying to get the pivot pins for enough hours I'm about to give up on them. Everything I"ve put in them snaps off, then I have to drill and tap and drill and tap. About ready to burn a Squarebody to the ground. Sooooooooo, At this point, I"m about to swap in the steering column which I really wanted, from the 91 Suburban. Anyone happen to know if there any differences in the 84-91 columns? Will all the plugs line up and such?
The harmonica plug will line up.
After 1985 the wiper and dimmmer will mate up. Not sure about 1984.
Do the Jeep YJ steering shaft upgrade and you won't need to worry about the steering shaft.
If it's from a GMT400 CK chassis I'm not sure.
Sent from my SM-P605V using Tapatalk
