Ignition HELP! [solved]
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
New dist came in. I swapped over the coil and cap, thats all. I can hear it misfiring. Well, ****, it might be 180 now, lets just spin it. Now, nothing. No misfires, nothing. **** me. are you serious, a 2nd coil?
Okay, this isn't usually the the problem but it has to be checked:
I know you have confirmed 12 VDC at the ignition coil's BAT terminal - but that was probably with the ignition switch in the RUN position.
On the other hand, have you tried doing the same check - this time while the engine is being actively cranked? If not, you should.
There are certain issues that can develop within a starter motor - that when operated (e.g motor windings shorted to ground) - will cause it to pull the overall system voltage way down. Even though the rest of the system is in an undervoltage condition - the starter retains the abilty to crank the engine normally.
The spark developed in the secondary circuit of an HEI distributor will begin to sharply deteriorate once the voltage supplied to the primary side falls below around 9-10 VDC. Initially it weakens to a yellow color, then it becomes a feeble orange that barely can jump the gap at the plug. Finally at about 7 VDC (to the primary) the secondary voltage is so low it is unable to produce any spark at all.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Ha, funny thing... I do have a brand new starter to also put on. Ill put it on in the morning and let you know if that changes the problem. I have had starter issues which is why I ordered a starter. God I hope thats not the issue, butttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttttt.
I have some drinking to do and some football to water this evening. And right now, thats better than messing with this truck. BTW, both off these issues started at the same time, which, now that you bringing it up, the distributor issues could totally be from the starter issues that started first.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Replaced the starter. Cranks harder, doesnt start, no backfire. Replaced dist base with brand new base with brand new coil and turned 180... cranks, no start. this is pissing me the **** off.
gpmorgan
Tupelo Ms.
greg
How many miles are on the engine? Has the timing chain ever been replaced?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Don't know that. The problem is the secondary ignition. For a fact. I heard misfires my first start up today and haven't heard them since.
I mean, what are the chances on 2 bad coils?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
I saw on another board about checking reverse lights and turn signals but I KNOW I'm getting 12 volts to the coil.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Starter is brand new as of 6 o clock and it's one of those updated new style starters. I have the whole electrical test sheet on it so I know it's good. Cleaned off the wire connectors.
So. Correct me if I'm wrong.
12 volts for the coil comes from the starter. The starter has 12 volts at run. Turn the key to start, starter moves the flex plate which in turn moves the cam and the rotor to the tabs under the cap. Coil discharges itself when it moves in line with the cap tabs.
What would prevent this coil from discharging?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
Could it actually be this ignition switch in the steering column? The start 12 v comes from b2 and it's the ignition switch that usually bad?
Georgeb
Wisconsin
George
K10 Burb Z71
Is that little ground bar installed under the coil?
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
I didnt tear apart the new one as it is a complete dist. On the "old" one, yes, it was installed.
gpmorgan
Tupelo Ms.
greg
An easy way to verify the coil is firing is to remove a plug wire and have someone to try and start it while holding the plug wire close (1/2 inch or so) to the exhaust manifold or something metal on the engine and see if it sparks. I've seen timing chains jump a tooth or two and not backfire or anything. Usually the engine will turn over really fast like it has no compression.
These two are entirely wrong:
The power supply for the B+ terminal at the ignition coil comes directly from the IGN1 terminal in the ignition switch via the PNK 3 lead. The IGN1 terminal also supplies the IGN bank within the fuse block - using the same PNK 3 circuit. IGN1 is hot whenever the ignition switch is in either the RUN or START positions.
The starter (the solenoid actually) always has full battery power available on the line (inlet) side of the it's main contacts (it comes in on the big black cable that runs up to the battery positive terminal). The other side of the contact set is connected to the main starter motor windings. When the contacts are closed - by the solenoid - the battery is then directly connected to the starter windings.
There is a small lead (PPL 6) that is connected to the "S" terminal on the solenoid. The other end of the PPL 6 lead passes through the firewall and connects to the NSS (neutral safety switch) at the base of the steering column. It exits the NSS as the YEL 5 lead. That YEL 5 is connected to the SOL terminal in the ignition switch.
When the key/switch is moved to START, the SOL terminal is energized. Power then flows from the SOL thru the YEL 5 lead, across the NSS contacts (if the gear shift is in either P/N) and into the PPL 6 lead. The PPL 6 lead supplies the solenoid with power on the "S" terminal.
When the solenoid coil is energized, it pulls a plunger in. When that plunger pulls in, two things happen:
1. Indirectly, through linkage, the starter pinion is moved outward where it engages the ring gear on the flexplate/flywheel.
2. A copper bar - attached to the other end of the solenoid plunger - bridges the contacts and begins to supply the starter motor windings with battery power.
So, at that point, the drive pinion is engaged with the flex plate and power is available to the starter windings. With power applied, the motor spins and drives the pinion shaft & gear. The pinion gear drives the ring gear/flexplate assembly. And, because the rotating flexplate is bolted to the end of the crankshaft...the engine turns as well.
When the operator senses that the engine has fired - and is running on it's own - the ignition switch is released and allowed to snap back to the RUN position. The PPL 6 wire goes dead and stays that way until the next starting event.
Meanwhile, up at the distributor, the ignition coil - which has been receiving power from the IGN 1 terminal (on the PNK 3) ever since the key was moved from the OFF position, is providing the spark plugs with 40,000 volts for combustion.
This one is essentially correct - only the crankshaft is missing:
This one is kind of true.
Actually the coil (and the rest of the distributor's electrical components) have no idea where the rotor tip is - in relation to the cap's terminal posts - when it discharges a spark. That's why we time the ignition ourselves.
The secondary ignition circuit (in the distributor) generates- and makes available to the plug wire posts - 8 sparks per revolution of the distributor shaft. All of these sparks are evenly spaced and one will fire every 45 degrees of the rotor's 360 degree full rotation. No matter where the tip of the rotor is - in relation to the terminal posts (which are of course also evenly spaced and 45 degrees apart), the coil will attempt to discharge the generated voltage. The 45 degree spacing is a function of the pickup coil and the spikes in the reluctor ring.
The object of timing an engine's ignition system is to get 3 things synchronized:
1. The spikes on the reluctor ring (and by extension, the tip of the rotor), with the
2. Plug wire terminal posts in the distributor cap, so that when those two are in line the
3. Associated piston is at TDC (actually a bit before)
Actually almost nothing would prevent the arcing of 40,000 volts - nothing that would be found in a distributor cap anyway. If no spark is evident at all, it would be safe to assume that no voltage is being developed by the ignition coil's windings. The problem is not with power transmission, rather it is most likely with power generation. You yourself have remarked several times about the lack of even a backfire.
Bottom line: if an HEI distributor is supplied with 12 VDC at the B+ terminal, that is basically all that you can do - externally. Any other condition - that would prevent the generation of proper voltage to create a spark - would almost surely be internal to the distributor.
74 Shortbed
Very well said..
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Going by what @chengny described, if you don't have 12v on the B+ terminal of the distributor with the key in the "run" position, it sounds like the starter switch (not the key switch but the switch lower on the column) could be bad. If you have no voltage on the B+ you could try to run a jumper wire from the battery to the B+ and try to start it again. If it fires you know the problem.
Jimc21NC
