Ideas as to where this problem is coming from?
WesN
Edmonton Alberta Canada
Wes
C1500
I think I found my leak on the right kick panel. Just have to wait for spring to drive in the rain to find out for sure.
Craig 85
Nashville, TN
454/TH-400/NP205
That's where mine was leaking from.
sirweesarunch
Oceanside
Squarebody achilles heel. This comes from the cowl area on the outside of the vehicle right under the windshield wipers. You need to remove the hood , take off that plastic screen that attempts to keep leaves out and look down into those holes. There is a seam down there that the seam sealer fails , water gets under it , it rusts through and allows water to run down the back of the dashboard under the rug and rot the floors out. You need to scrape all the **** out of the cowl seam , clean it , epoxy prime it and then seal it back up with Sikaflex to keep water out of the cab. Its a total ballbuster of a job. I replaced everthing you’re getting ready to do because of it.
goodwrenchca
