I'am Going To Build A Smooth Idle 427
Mark Jones
Horse Shoe Bay Tx/Thousand Oaks Ca
Mark
4.350 x 3.764, 9.7 compression, 1971 820 GM oval port heads, Comp cams roller tip rockers, .080 wall chromoly pushrods, factory 390 HP cast iron intake with a Q-Jet. The centerpiece of my build a 350 HP 396 factory hydraulic cam 214/218/460/480/112 with 1970s TRW hyd lifters. Some pictures.
Following along...
Mark Jones
Mark
Some more pictures
MikeB
North Texas
That should be a fantastic torque monster! Where did you get the camshaft and lifters? And is the manifold NOS? If not, how did you get it so clean?
Super clean shop you have there!
GXPWeasel
Kansas
Greg
1982 | 2015
Sierra C15 | Silverado Z71
5.0 | 5.3
Looks beautiful!
Mark Jones
Mark
Thank you. My cam grinder RED LINE used a 1960s GM cam core, then I found 1970s new TRW hyd lifters because I wanted complete reliability with the factory GM lobes. I clean all cast iron In a hot tank.
80BrownK10
Greenwood, SC
Nate
More pictures
My gosh is that a shop or an operating room!!:eek:
Wumbo
Illinois
Rob
More pictures
Why is there an engine in the laboratory?
Carb'ed Vortec 350
That is bad ass!! Yes, we want to hear this thing fired up!
Catbox
Peter
C20 Silverado Camper Special
Thank you. My cam grinder RED LINE used a 1960s GM cam core, then I found 1970s new TRW hyd lifters because I wanted complete reliability with the factory GM lobes. I clean all cast iron I a hot tank.
What did it make on the dyno?
burton97
