You only live once so might as well go talk to the banker on this turn key deal. He even has a 1 yr warranty. To my knowledge no one else offers this. I have a little less in mine, but at 12 yr old prices using my iron heads, building it myself, and not broken in and dyno tuned. 10 grand for an LS, I wouldn’t do it , 14 and change for this is a bargain as far as I’m concerned.
Just something to kick around in your head.
Pro/Street 383 Stroker
566 Horsepower, 383 Small Block Chevy, 350 Dart Block with ARP Main Bolts, Double Keyed Eagle Cast Steel Stroker Crank, Eagle Rods, Hydraulic Roller Cam and Lifters, Double Roller Timing Chain and Gears, Polished Aluminum Timing Cover, Polished Aluminum Finned Oil Pan, Double Keyed Pro Products Balancer, Complete Rotating Assembly Balanced, Forged 8.2 to 1 Compression Blower Pistons, File Fit Moly Rings, Polished 64cc Aluminum Heads with Manley Stainless Steel Valves, Chrome Moly Retainers and Locks, Comp Cams Springs, ARP Screw-in 7/16 Studs, Stainless Steel Roller Rockers, Polished Aluminum Valve Covers, Polished Intake with Stainless Hardware, Polished 671 Supercharger, 3 Inch Drive Pulleys and Belt, 2 Edelbrock 750 Carbs, Linkage, Fuel Lines, Funnycar Style Belt Guard, Polished Dual Carb Scoop with K&N Filters, MSD Ignition, Set up, Run, Synchronized and Dynoed.
$14,360.00 Turn/Key #558A
