AyWoSch Motors
The Parts Guy
- Nov 6, 2020
- New Mexico
- Ayden
- K1500 Sierra
- 350ci V8
Hello. I need some help, I'm going crazy trying to tune this engine.
I recently put a new 350 in my 86 GMC and now it runs and drives, but I can't seem to tune the engine right.
It's a L98 350 out of a 85 TPI Corvette.
I have an Edelbrock performer dual plane intake and right now a Rochester Quadrajet, but I had an Edelbrock AVS650 on it before and couldn't make that work either. Brand new fuel pump, fuel filter, brand new 65k 4pin HEI, with 10.5mm HP plug wires and new plugs.
When I had the engine on the run stand it ran quite well so it appeared, but after I got it in the truck, it didn't.
I messed with it and tinkered with it, but couldn't get it quite right. It had a weird pitter patter lopsided exhaust sound. And it smelled like gas out one exhaust pipe ( dual exhaust).
After telling my boss (the PO), he said that he had put mis matched jet sizes in that edelbrock to make it work on the old 305 because it had a weak cylinder on one side.
So I took that off and put a Rochester on that was tuned already for a 350 and I knew ran well, thinking that would solve the issue. Nope. It runs a little better now, it will stay running, choke works, and it will idle, but it's not happy.
It will only idle at about 1600-1800 RPM, any less and it wants to die. It has the same odd sounding pitter patter lopsided sound out the back. It also does an odd slight little rev at random while its idling.
I took the carburetor apart, and cleaned it and put it back together, and same thing. I messed with air/fuel a bit until it sounded a little better, then I had my friend who is really good at tuning come over and mess with it. He got it to run a little smoother, but still not great. Can't get it to idle down at all. And after we tuned it to sound a little better, when you rev it, it stays revving higher for a second after you let off, then it comes down slowly.
Also checked the timing. The way its running right now at such a high idle, it wont give an accurate reading. It says it's about 16-18 degrees BTDC with the advance unplugged, but that's also at about 16-1800 rpm. When I had it on the run stand and kt was running smooth. I had set it to about 10 degrees and it sounded great. I'd assume that hasnt changed as far as base time goes.
But we did mess with it anyhow too, it seems to like more advance, did smooth out a little the more advanced it, so I reset it a little higher.
We took it for a ride after all that. The thing freakin flys. It runs great when you're driving it, doesnt bog, sounds smooth, just goes. Way better than it used to, its almost scary fast now. Likes getting romped on, did a nice burnout with a locker, very easy.
.... but, as soon as we get back and park it, it's running like crap again.
Super high idle, cant lower it, choppy exhaust sound, weird little surging thing.
I have no clue why, both me and my friend agreed its the most fickle engine we've ever tried to tune. Just work run smooth no matter what we do.
Anyone have any ideas, please help. Thank you.
