Troyport
- Jan 15, 2025
- ohio
- Mike
- V20
Hi all, 1987 3/4 ton pickup, hydraulic clutch. The clutch engages very high. Does not slip. I have read that it needs to be bled, but if there was air in the system wouldn't it engage very low in that a lot of piston travel would be compressing air which would translate into not much movement of the throw out bearing? I have had (and still have) several Chevy trucks with mechanical clutches, easy to adjust engagement height.. this is my first hydraulic chevy. Thanks for any input.
