Humvee 6.2L Diesel Switchout
Sharpend
Hampstead
Tay
6.2 Diesel
Has anyone done the Humvee swap out? I own a 1985 C20 and have a crippled engine. I have been able to locate a new surplus Humvee 6.2L diesel from Camp Lejuene. The pulley systems don't run exactly the same and they may be one or two other slight differences but I think it will work. Any thoughts...
marks86
Latham, NY
Mark
12v Cummins
pulley system is different and manifolds are different
Sharpend
Hampstead
Tay
6.2 Diesel
marks86...I am not a mechanic but will pay for a good one. Can the pulley system and manifolds be overcome.
marks86
Latham, NY
Mark
12v Cummins
I would research it more but I know for a fact the manifolds are a direct bolt in with new gaskets of course. as for the pully system I don't see why you system will not work
google hummer 6.2 to trucks swap or something along those lines. Im sure many others have done this swap because there are tons of those motors in crates from when they changed them all out for 6.5s
MadOgre
NA
NA
NA
NA
NA
Don't they use the same blocks.
Couldn't he just bolt all his C20 stuff onto the Humvee block?
marks86
Latham, NY
Mark
12v Cummins
I guess that's a lot simplier way of explain it thanks madogre:party36:
bottom line here is bolt c20 stuff onto Humvee block
MadOgre
NA
NA
NA
NA
NA
Im just assuming there the same blocks. I dunno. I thought you might know for sure?
marks86
Latham, NY
Mark
12v Cummins
bottom line is bolt your c20 stuff to the Humvee block
BigMike88
