How to support the frame during leaf spring change?
fltplan
Prescott, AZ
Steven
K10, LWB
I'm changing out leaf springs, ie, installing a lift on my 79' K10. The truck has approx 2.5" of lift right now. In order to support the frame I have used a stack of 2x10x12's about 8 high, then a jack stand on top of this at a pretty low setting. This is on a concrete floor and still isn't all that stable. Doing one wheel at a time so it's just one corner supported. It doesn't take much to get it to sway. Aligning the leaf with the axle requires a little muscling around and I'm not comfortable with the way it's sitting right now.
What have you guys done to support the frame? It's approx. 30" off the floor .
4x10's stacked? Thoughts? Thanks
chengny
I think that's the problem. You should have the rear end up and level - with jackstands under each frame rail. Use your floor jack under the differential to release the strain on the spring stacks.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I made a couple boxes out of 2x6's more than wide enough for a jack stand to sit on top of. Pretty sturdy using a pair of those. Wasn't tall enough to be able to remove the wheels when the frame was supported.
Had to lift the axle with two jacks first, pull the wheels, then place boxes with jack stands underneath frame, lower axle to let it almost hang. Placed a block under the yoke so it won't rotate, then pulled the ubolts and all.
fltplan
Prescott, AZ
Steven
K10, LWB
Exactly right, put it up on both frame rails, problem solved. Got rid of the jack stands and invested in some blocks of wood.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Glad to hear you got it all sorted out. If you're only using blocks of wood, just make sure you've got them wide enough so that they're not gonna shift on you and flatten you like a pancake. Our trucks are far from anorexic.
The88
Mhmm
South Louisiana
ThatGuy
This is how I set mine to keep the truck as low as possible and give me room to work. Single jack under the chunk, set jack stands high on blocks to remove the wheels. Once I popped those guys off bumped up the jack and lowered the stands, then lowered the jack back down onto the stands and voila. Railroad ties work wonders.
RThiel
Worland, WY
Robb
6.0 LQ9
I agree that you need to do two at a time. Go get some 4x4 posts, cut them into 24" lengths, and then build "log cabin" style bases to set your jack stands on. I was in the fire service, and when we'd stabilize a vehicle to perform extrication with Jaws of Life at a wreck, we'd build bases like these to keep the car from moving. They call it "cribbing". Anyway, 3 posts cut into 24" sections will get two jack stands up 11.5" (assuming the posts are actually 3.5" square), then you can pile them up in a corner somewhere to use again later, or burn them in your next campfire.
fltplan
Prescott, AZ
Steven
K10, LWB
All done, worked great.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If you have a receiver hitch I made a stand that slides in mine. Then you can use small stands to hold the rear. I can post a pic if you want. Its nothing special though.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Sounds pretty cool, mind throwing up a pic?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Easily removed when the rear is back in. Just some scraps I had laying around
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Here is another
jimlayhee
