How to make a daily driver?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
lol, I was wondering how long it would take for you to notice that.:happy175:
I think the same thing when i see someone say bumper thingys lol.... hmm wheres honky... :laughing1:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Good lookin stepper
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’m aggravated today so I’m limiting my involvement today.
74 Shortbed
Looks like he even found some bumper thingys for it too. They really give the front end a good look.
Fixed it for ya.. :D
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
I kinda like the Hankook ATMs I put them on the wife’s AWD Edge and it’s unstoppable in the snow. Plus it looks a bit odd because they are a semi aggressive truck tire on a CUV lol
+1 on the ATMs on small AWDs. They are a good balance between mud and snow. Don’t ask how I know, haha
roundhouse
atlanta ga
justin
77,78,79,80 ?
That’s one of those nice looking oxidized paint combos. I’m liking how the fender is painted from that angle.
You have anymore pictures from different angles from the back?
I can take some
75gmck25
Northern Virginia
Bruce
My K25 has been a daily driver, on and off since about 2002 when my oldest son starting driving it to school, followed by his younger brother taking it over 3 years later. I have a few suggestions about how to keep it reliable.
- Fix things as they go along, and fix them correctly, using the right parts. If the book says you need to replace additional parts as part of a repair (for example, when you replace brake pads there are other parts to replace), then do the job like you were a repair shop getting paid for it. Use the right lubricants, and check everything with your torque wrench. You don't want the customer (you) to come back with problems.
- Sticking with a configuration very close to the factory setup will be more reliable and require less tweaking. For example, running stock 31" tires and no lift is not that exciting, but it will require less fixing over the years. When you run a lift and big tires you need dropped steering arms and new springs, and your tires/wheels will need more offset to fit in the fenderwells. I am not saying this is bad, but if you leave it stock it will simplify your maintenance. When you run wheels with more offset you should be servicing the wheel bearings regularly and looking for wear. If you run stock tires and wheels you can run it for many years without even worrying about it. Stock tires are also cheaper, and available everywhere if you need a replacement (Walmart, etc.).
- In some cases, converting to a more modern configuration (LS engine, EFI, etc.) may make the truck more reliable, but make sure you are really getting a complete, reliable solution. If you buy a partial solution and then have to figure out the final wiring, fuel supply, etc. on your own, you just became your own personal automotive engineer. This is not fun if you started your project Saturday morning have to use the truck again to go to work on Monday.
- Make small upgrades that will help the truck be more reliable and work better. For example, gas with ethanol eats up the old stock rubber fuel lines, so swapping in new EFI rated hoses will reduce the possibility of a leak. When you replace bad rubber bushings, use the poly bushings that should last longer. Or when you buy brake pads, buy the performance version instead of the stock replacement.
Bruce
roundhouse
atlanta ga
justin
77,78,79,80 ?
SDJunkMan
Black Hills of South Dakota
Jeff
If I had know how easy it was to swap beds we would have bought a fleet side.
Four speed Stepside is hard to fit
Great looking truck, that's the stance I want on mine. Ideally I wanted a 76 stepside with a stick, but bought a 78 Fleetside stick and a stepside bed to swap onto it.
Is there a body lift on it, or just the 4" suspension lift?
4WDKC
Southern Florida
Kacy
Something to look into would be finding a 96-98 2500 4x4 350 vortec truck. Pull the drive line, and wiring harness. That way you have OD in the tranny and fuel injection. Then start researching the upgrades you want to pursue.
My suggestions there would be :
different intake with standard type injectors
Cam
411 pcm swap
Thats a lot of work to end up with a 350 vortec and the intake/injector replacements arent cheap, much better off with doing a LS swap. The LS already has the mpi intake 0411 ecm and can be bought for about the cost or cheaper than the MPI intake for vortecs.
roundhouse
atlanta ga
justin
77,78,79,80 ?
It has hockey pucks for a one inch body lift
Edward Tofflemire
