bigcountry78
- Apr 16, 2013
- Hickory, North Carolina
- James
- K10 Custom Deluxe
So after doing ball joints and tie rod ends, and putting everything back together, I quickly found out that the front spindle nuts were too tight after a short drive. The front hubs were too hot to touch. Like, so hot you wouldn’t be able to put your hand on the hub to engage 4x4. I took them apart and backed the nuts off to were I think they should be. My hubs are still hot after a a 10 mile trip at about 50 mph, but it’s only the part behind the dial. The actual dial and chrome cap behind it are fine. And the body of the hub isn’t so hot that you can’t touch it. I can put my hand on it and leave it, although it’s not the most comfortable thing ever. So am I good to go, or are they still running too hot? I understand that brake drag and ambient temps also play a part here.
