How do I fix this?
jux
PA
Z
It's more than that. Read the description. It has insulation sandwiched between two metal plates. Can you link the heat shield you used? Thanks.
Oh, ok.
http://www.autozone.com/autozone/ac...s/_/N-268nZ1z11tvd?itemIdentifier=398831_0_0_
Most autozones have these right on the shelf, in packs of 2. I used one to slip over the starter wires, and just put the other one over a spark plug wire that was a bit close to the header.
Think I paid about $7 for 2. You can also get packs of 8 I believe, if you wanted to slip them over every spark plug wire.
jimlayhee
