Kapdin
- Jul 26, 2012
- North Dakota
- Lance
- 1977,1979,1984,1987,1988
- Silverado K30, Scottsdale K20, Silverado C10, Silverado V10, Silverado V20
- 400ci, 350ci, 350ci, TBI 350ci, TBI 350ci
spent the last hr researching q-jets. im trying to forget everything ive learned to see if im just dumb but so far ive found wat jims talking about
Tech Tip #3
How can you tell if an off-idle stumble is caused by a lean or a rich condition?
A carb running rich, as well as a carb running lean, can cause an off-idle stumble or hesitation upon acceleration. To narrow it down,
tap the roll pin out of the accelerator pump lever by using a small pin punch or a small finish nail. I actually use a small, broken drill
bit that’s just the right size. Using a hammer, gently tap the roll pin in towards the choke air horn wall. Don’t jam the pin right up
against the wall: Leave just a little bit of a gap so you can get a screwdriver blade in between the wall and the pin to pry it back again.
With the pin tapped out, remove the accelerator pump lever. I like to do this with the engine running so I won’t have any trouble
starting the engine without the accelerator pump. Now, rev the engine a little with the throttle. Notice if the engine seems quicker and
more responsive, or if the hesitation & stumble is worse. If the engine actually feels more responsive with the accelerator pump
disconnected, you have a rich condition. If the hesitation is worse than before, you have a lean condition. If there is no change
whatsoever, you have a non-functional accelerator pump.
To verify a suspected lean condition after this test, simply hold your cupped hand lightly over the choke air horn area with the engine
running at idle, restricting the air flow. If the idle speed and idle quality momentarily increases, you have a verified lean condition.
You need to select a jet/rod combination that will give you a little more Cruise Metering Area. Make these changes in less than 10%
increments using the Figures provided in this paper.
Tech Tip #3
