home made cross over steering?
Hello I was wondering if I would just be able to move my dana 60steering knuckle and block to the pas side and run some tubing to the pitman arm for a cross over??. I do have a 2wd steering box on a parts truck any impute would be help full. I do have a welder and can weld ok. I have tap and dies to 1 inch also.
For that to work, the steering arm would need to point forward, but it can't bolt up like that.
Chuck
Grande prairie
Chuck
K30 crew cab
I just bought a 6.2 to drop in so i think I'll just buy the kit. I don't got time mess around with the steering. Thanks for the impute
Sent from my iPhone using Tapatalk - now Free
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
I've got a offroad truck I'd like to change over to crossover sterring since it never steers right when flexed different on the trail. Also I break the left front spring quite often. Only problem I have is that I run stock springs on front with 38" tires. I don't want to put a lift on it so is there any steering options for mine to make it steer right?
Chuck
Grande prairie
Chuck
K30 crew cab
Get a dodge dana 60 steering set up from a junk yard
towjoe
Lafayette,IN
joe
K30's or V3500's
Kingpin or ball joint dodge 60?
Chuck
Grande prairie
Chuck
K30 crew cab
I bought the kit off eBay for 250 it work really well
botcheddd
