tpripps
- Aug 23, 2021
- Scandia, MN
- Tyler
- C30
So a while back I had posted about a rear drum that was stuck and some of the methods I used to unstuck it. One of the methods I tried was to drill two holes (one on each side) of the brake drum, about 3/16" dia, and used a punch to try to drive the pads free from the outside. Being that there is now a hole in the wear surface, do you all think I can reuse this drum, even on a temporary basis? I don't expect to do any highway driving, towing or hauling until it's replaced with new, but I also don't want to stick a ton of money into drums (about $150 per side, before shipping) until I give the ol' truck a road test. I just don't want to destroy new pads by having a weird spot in the drum. Maybe I just block off that corner and do 3 wheel braking for a little while...
