Holley sniper efi
1badk20
British Columbia
Daryl
5.7L
looking at getting a holly sniper EFI kit for my 1977 k20 with a 350sbc
Just curious if anyone else is running one and how they like it ?
@bluex is running one, and has been for a little while now.
bluex
Spartanburg SC
C15
Yep I probably have close to 5000 miles on it now. I'm pretty happy with it overall.
There are various reviews on the different EFI options, and always quite a few successes and a few failures with each brand. However, the consist theme I see is that you need to spend some time on setting a good fuel feed into the system. Just tacking on an external EFI pump and a few extra lines may not work very well to make a system reliable.
You need a good EFI pump, properly located (in a baffled tank is best, mounted low on the frame should be okay), and you need all the right size feed and return lines hooked up with good quality fittings. The other option is to use a surge tank or similar device to ensure you always have fuel properly feeding to the EFI. I have considered the surge tank option, since you can still use your stock dual tanks and mechanical pump to feed the surge tank, and all the high pressure is between the surge tank and the EFI. One example is the Fitech Command Center 2, which includes the surge tank and pump as a unit. It looks pricey until you add up all the pieces you would need to build your own.
rpcraft
Robert
LS 6.0 364 CID
The fuel supply is often the most overlooked item and causes a lot of grief.
bluex
Spartanburg SC
C15
You can do an in tank pump with factory parts cheaper than that fuel sump garbage.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
In tank is super cheap. New 1987 baffled tank, sending unit and 60 psi pump are around $200.
Another small cost is to replace any rubber sections of fuel line with high pressure stuff and run 12v from the fuel pump wire on the sniper.
rpcraft
Robert
LS 6.0 364 CID
Spectra used to sell a setup that includes the tank and the sending unit (of which the sending unit is often quite expensive comparatively speaking) and then you can go online and get a reputable fuel pump for that sending unit. As others mentioned you want to get the parts from a TBI injected pickup, (or blazer or suburban if that is your poison). You can get reliable and non-chinese fake pumps from a supplier such as http://www.fuel-pumps.net/ If you try to get away with buying the cheapest chinese (amazon) pump you can find then you better make sure and buy multiples, and make your tank super accessible because you will end up needing to change them out, often at the worst time, like right after filling your tank (because the pump starts failing and you think maybe it's reporting the fuel level wrong and you fill your tank to make sure that isn't the issue.
Spork
