Holley Sniper and Gas Tank Swap
chuckler3
Hillsborough County, FL
Charlie
350 SBC
It started. First fire up when fast and easy (after re-seating the SD card in the brain box). The next two were chuggy on the starter.. Haven't sorted that out yet.
Still have to set idle once up to temp, which it got to, but the skies opened and it was time to call it.
No fuel leaks to see, coolant is hot as hell but still inside the motor.
Tomorrow will be bleeding brakes and driving it around the immediate area without the bed or tails to "learn" it.
CRM
Pasco, Washington
Casey
K2500
350 CI
You know this thread is hard to believe without pictures, right???
SquareRoot
Pictures? It's either running good or it's dead.
chuckler3
Charlie
350 SBC
ok... This was yesterday.. Bed went back on today.. Found out that 2 of the 8 bed bolts are kinda boxed in by the new gas tank. Gonna take some narrow forearms and some coaxing to get the nuts on those bolts.
Still have a small leak on the distribution block for the brakes. Have to tighten the headers again, and finish mounting the bed-mounted fuel fill neck (Spiders are fast round here.. I put those pieces in an hour ago)
83 Box
