Holley 2d injection anyone tried it?
Fell into complete 2d system off a running Chevy 350. Has anybody run this system? Any recommendations or comments about it? I have the 350 tbi motor out of my burb basic stock 30 over 350 193 heads computer friendly cam ran great in the burb. Was going to stick it in my 85 c10 with a qjet and call it a day,but this looks like a dirt simple way to get tbi in the 85. I'm in this so cheap I thought I had to buy it. It's complete,fuel pump harness relays o2 sensor everything. What if any stock gm tbi stuff will work with this if I use it for pieces or if I need replacement parts? Thank you all. You know even stupid ideas like come across my head like using it just for the tbi and the pump and trying to run it off a gm 0411. It's not for power it's trying to make the same kind of milage and drivabilty I got out of the burb.
Which system is it? Does it have adjustment knobs on the ecm?
I never heard much good about those early systems, but of course, they also were rare to see in use in my area.
Yep it's got adjustment knobs,probably not even going to use it.It goes against my normal model of doing things. But it was so cheap that this little voice kept saying buy it,buy it,you can't pass this deal up buy it. I know you don't need it but you should buy it anyway. Well common sense lost. NBD
Hey fwiw, when I said I had my reasons for just wanting a 72 or earlier A body rearend,was because I knew the cast mounts on the pumpkin changed in 73 and the rearends got a bunch wider. I've still got tons of 8.5 stuff,zero 12bolt,zero 8.2 stuff zero ford 9inch stuff. Anyway thanks for yours and everyone else's help and attempts
CJCatcher
