i ordered all 3/8 stainless fuel line, so whatever the equivalent is. i figure i'll get as much done with the rigid lines, flaring tool and nuts, then make a list of flexible stuff and fittings and buy that locally. i live a little over an hour from a pretty big speed shop.
what's a high quality flex line thats not like $100/foot?
Yeah, the speed shop is the way to go so you don't have to buy a whole 20' roll of stainless braided fuel line at Jegs for 75.00. If they're gonna try to get 10 bucks a foot, or something stupid, you may want to just get a roll. You can use the extra on your Yugo or some other project later....
http://www.jegs.com/i/JEGS-Performance-Products/555/100914/10002/-1
Easy way to remember the AN sizes....
Just remember AN-8 is 1/2". Then do it like fractions. (AN-) 8/16= 1/2 after you reduce it down. SO, (AN-) 6/16= 3/8. If you can remember that AN-8 is 1/2, then you can figure out the you need 16 as the denominator. Cake, or did I totally confuse you??? Lol. I don't know, the sh*t makes sense to me.... QUIZ TIME! So what size is AN-5? Haha. *KEY POINT HERE* AN sizes are for the outside measurement. If you require a line to flow inside, at least like a normal 3/8" hose, then you need to step it up your fittings and hose one size. Thus instead of an AN-6 for the 3/8" flow, you would want to use AN-8. The inside flow size is ~about~ 1/16" smaller than the fitting size. WHEW.....
If you haven't used these fittings, then have them show you how to build them (and how to cut the hoses), or YouTube it. You have to get the fittings into the hose all the way, and make sure they don't back out when tightening.....
Another option you have is to get hard fuel line that will work with the AN fittings, and run it from tank to tank, instead of braided. Your choice. Gotta make sure your flair tool has the proper degree crimp on it too. AN uses 37 degrees. SAE is 45 degrees. Pretty sure that your stainless line won't work with the fittings, unless things have changed. It has been quite a few years since I've used them.
