High Beam?
Gus Moore
Arkansas
Gus
So while replacing the high beam switch on the steering column I pulled the little rod out of the signal by the wheel. How do I get it reconnected? I can’t easily figure out how to even get access to it? Thanks in advance.
350 w/203
Pix of the place of separation. thx
RoryH19
Rory
R10 Silverado SWB
It came apart at the top lever or you are having issues toward the bottom of the column?
Pic would help
Gus Moore
Arkansas
Gus
At the top lever. Where it goes into the actual lever you pull to turn high beams on and off. The rod slid down and out. Away from the steering wheel.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
to the best of my recollection you should be able to push the rod back into place just operate the lever so you can feel it engage and then reinstall the switch.
Gus Moore
Arkansas
Gus
It’s the little rod that runs down the steering column from the lever and into the new high beam switch I bought.
Gus Moore
Arkansas
Gus
That’s what I was thinking but I haven’t been able to get it into anything yet. And you can’t actually see the area it goes in because it’s covered up.
Gus Moore
Arkansas
Gus
Online it has the most complicated directions of getting back in. Getting a special tool to take the steering wheel off. Then removing all the steering column cover, just so you can see the tiny hole the rod goes into.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
With the switch on the bottom out of the way, you can probably push the rod back up top and when you operate the high beam lever feel it move. It just has a curved end that butts up against a little plastic piece. One you have it in place, hook the lower switch back up.
Lots of pics here :
http://www.fiero.nl/forum/Forum2/HTML/088020-3.html
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Jazzman has a Saginaw tilt column assembly tutorial in the loose steering column thread. Lots of pictures that show you how to assemble your column.
Sent from my SM-A705U using Tapatalk
MrMarty51
Eastern Montana
Martin
The special tool for removal of the steer wheel is two legs under the wheel, pressing against the steer wheel and with the horn cap removed and the nut screwed part of the way off to protect the threads of the steering shaft, rap the top of the nut/shaft with a hammer, might take several but it will pop against the nut, then remove nut and steer wheel.
You want the nut to be just a thread or two above the shaft. If done proper, the nut can be reused.
RoryH19
Rory
R10 Silverado SWB
I recently had to tighten the tilt column on my 87.
I was able to borrow the removal tool from Autozone.
If you can't fish it back into position from the bottom you will need to pull the wheel and lock plate.
Then you will be able to access the high beam lever.
MrMarty51
Eastern Montana
Martin
And there is a tool for compressing the lockplate spring to get the C ring removed in order to get off the lockplate.
Gus Moore
Arkansas
Gus
Thank y’all for all the info. I haven’t been back in here in a bit because my baby. My 85 Chevy K10 was stolen back in June in Fort Smith, AR.
Auburn, Washington
Chitty deal....
Probably no hope of getting it back now, months later?
ESONE
