Hi there.....Got a Geneva Suburban
This is going to be a tough one buddy. Reason being, you don't know if those mice chewed up some wires somewhere and if so where at? So did you replace the WHOLE DISTRIBUTOR INCLUDING THE EIM? Elecontronic Igntion Module????
So you have the engine cranking right? It just won't start? Let's try this. If you have the engine cranking as in the starter is working, let's do process of elimination. Get about a 4 foot wire closest to 10gu as possible. Unlplug the BATT wire on the distributor cap. Plug in a wire there are take it direct to the battery positive post. This is hot wiring the dizzy so WE KNOW 100% for fact it has power. If it starts, then we know it's a wiring issue between the dizzy and the ignition.
If it still doesn't start, then let's make 100% sure the EIM is good. Either borrow a known good one, or ohms test the one that's in it now. Obviously if it starts with the known good module then we know that was the problem.
If it still doesn't start, then it's safe to assume we have a fuel problem, which could be even wiring to the fuel pump.
RacingTurtles
Pennsylvania
Apu
v1500 Geneva Edition
350 tbi
Hey guys,
I ended up buying a new tank, delphi fuel pump assembly, and now im waiting on all new hoses and vapor canister purge valve. It made sense since I cleaned everything up back there and painted it. I'm not planning on dropping the tank anytime soon since its all new so I didnt re use the old stuff.
The 26 gallons of old gas in there is probably a big reason why it wont start/run. A mechanic friend told me old gas has been a reason for no starts on some of his older cars.
Just for fun I tested the fuel pump connector. It was giving me 8.5 Volts when in just the on position. During starting, it was going to -3 volts. This makes me think its the relay but then again the injectors were spraying. I will update again when I fill it up with new gas and try out the method above.
dvdswan
Port Orchard, WA
Dave
Welcome to the site. Looks like a great find.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
oldman
north fla
Ken
silverado 1500
LOL sorry for laughing ,I just went with my son to texas to buy a 87 chevy suburban that has been sitting for 20 years under a car port,it didn,t run 4 flats and critters that chewed wiring under the hood .After getting it home and accessing the damage lots of wiring chewed in half ,even heater hoses were chewed .Repaired the bad wires and thru a battery in it ,it would turn over but no start .Next day we removed the fuel tank and had 20 gallons of varnish WOW that was fun ,sending unit was bad so was pump after all these years rubber just killed the sending unit ,this truck is a one owner truck with all service records and has 80k origional miles inside and out is like brand new ,got it running and runs great for sitting for 20 years ,Ok lets take a ride WRONG ,mice chewed front brake hose thru lol and the saga continues
RacingTurtles
Pennsylvania
Apu
350 tbi
I appreciate the kind words guys.
Oldman, I'm with you. We just have a different set of problems but keep on chuggin man.
Good news, got her running. It was just the 26-28 gallons of old fuel. Threw in the new fuel tank, fuel pump, fuel filter, and did a quick oil change. Then proceeded to piss off the neighbors at 9:30 at night revvin it like a hoodrat. I did notice that the driver side injector is leaking from the top and I found a NASTY coolant leak. I haven't tried to move it yet. Who knows, could be a bad trans for all I know.
Time for more crap from Rockauto.
So 3 out of 4 of my cars are running. I'm working on the only non running one in my garage right now. I wanna get that going so I can actually move her out of the way and work on other cars when it gets dark out. It really sucks to have to plan things out around daylight hours. Let me go post up some videos after I go poop.
RacingTurtles
Pennsylvania
Apu
350 tbi
Hmmmm, never updated this.
So the truck basically went through a tuneup and new fuel system. I rebuilt both fuel injectors, bought a brand new fuel tank, fuel pump, hoses etc and it fired right up. I believe it was just a matter of bad gas, but I went ahead and replaced everything because God knows how old that stuff was. That fuel tank looked nasty and wasn't worth cleaning up when a new tank was pretty reasonable in price.
Drove the truck around for a lot of random stuff. I didn't even put 2,000 miles on it yet but I've loved every bit of driving it. I have a crapload of cars so I don't need to drive this too often. I've been driving it lately due to a bunch of cars down for repairs. Yes, I am currently driving this land yacht with gas being $5/gallon and getting like 6mpg.
Not much changed on the truck. I bought an additional 9 wheels of the Enkei Sawblades that are pictured on the truck for a total of 13 wheels.
I really love the wheels and want to keep it period correct. I got one set powdercoated a nice black with shiny flakes. Another set is meant to get polished.
I've been one of those idiots trying to buy a house in this crappy real estate market so I have not been spending money on any of my vehicles beyond keeping them running.
idahovette
Weiser Idaho
Perry
K20-K10
See above response
RacingTurtles
Pennsylvania
Apu
350 tbi
Huh, I didn't see that when I first opened the thread, but it totally sounds like something I would write.
LOL I do get yelled at for taking long in the bathroom but that's where my best ideas and game high scores come from.
Babs
Ottawa Valley
Chevrolet CUCV
John-Ryan
John-Ryan
V20
Welcome for east Texas! Now that's a green engine..EPA would love it lol
GorillaHumper
