Hi from TX
Clifton Kornele
Clifton
Hi I'm new to here. Just wanted to check posts for future ideas. Also anybody know of any decently cheap amp meter I can go and buy for parasitic drain test for my truck
MikeB
North Texas
I was just looking on the Internet and found that descriptions of clamp-on multi-meters are fuzzy at best. Many of the so called AC/DC clamp-on meters measure only AC current with the clamp, so make sure you know what you're getting. Also, you want one that measures as little as .01 amps. I've had one that measures DC current with the clamp for at least 10 years, but there is no name brand on it!
Worst case, you could remove either battery cable and connect a standard multi-meter (set to measure DC current) between the cable end and the battery terminal. Just don't turn on the ignition or any accessories! Some meters have a dedicated fused input jack for 10 amps. Others might be able to handle only 100 milliamps or so.
WFO
Texas Panhandle
Welcome from up in the Panhandle.
animal
Lee
c10 silverado
350ish
:welcome:
Steelers82
Perry
5.3 LS
welcome
1973c10
Don
:welcome:
86 SCOTTSDALE
Oakham MA
Armand
Welcome from New England
EastAustinSawdust
Austin, TX
Adam
C10 Big Ten Bonanza
5.7L 350
Welcome from Austin!
kirktim
