help with wilwood install
Daniel Salgado
San Antonio
Daniel
1983 C10 Just did wilwood rear disc brake conversion along with front wilwood rotors and calipers ,replacing master with proportioning valve, The inlet on the proportion valve is set up for 3/16” for front and rear, The original lines are 1/4” inch and 3/16”what would be the best solution?I’ve been searching for some kind of
adapter to step down the quarter inch line but I haven’t found one, Any help would be appreciated thank you in advance
eskimomann209
Modesto
Marcus
You don’t step down “the line” you step down or up the flare fittings with adapters.
Find what thread and pitch your line fittings are then find what the Wilwood prop needs. Thread the adapters into the wilwood then the lines into the adapters.
Are you keeping the stock prop valve in its location?
jbahena95
