Just throwing this out here for you.
I wont go into custom springs, (ord, alcan, deaver, etc...), but there is a big difference between off the shelf leaf springs and shock combo's, (I have ran many over the year's), The thing is ,( if you are not hauling loads and such) you want your front and rear suspension to work together as best as possible, so you say you may do a shackle flip in the rear with a stock spring which is a good thing, (keeping the rear semi soft). Then you go to a front spring that is stiff as hell, not a great combo for street or especially off road. When you get your front and rear springs set up to work together everything works like butter, (on or off road). If you go to a custom spring set up , thats when you need to start messing with sway bar's and such.
When you get your truck together, drive it without the sway bar and you will see you really dont need it with off the shelf leaf springs on a 1/2 ton pickup.
Here is some pic's for you, my k5 is all skyjacker soft ride springs, (8inch with a 1 inch 0 rate block) and 38 inch tall tire's with cross over steering and no sway bar. My wife drive's the k5 on the highway all the time at 80mph and it does really good off road. The k5 drive's like a stocker k5 and it is set up right for on and off road driving, (not to soft and not to firm).
The brown shorty is my girls first truck, got it with pro comp 6 inch springs front and rear and it sucked. Changed out all of the suspension for skyjacker soft ride and it was way better and pitched the sway bar. Still needed to be less firm in the rear so we went to a flatter rear leaf spring and a shackle flip in the back and it is all good now. Then went through the whole truck, engine , paint job , interior, etc...
I am not bashing anyone, I just wanted to give you some of the things that I have done with the many square's I have messed with over the year's, Me and my family love the 70's square bodies.
You and your dad have fun.
