Help With Hidden Kill Switch
roundhouse
atlanta ga
justin
77,78,79,80 ?
I bought a very small push button switch at an auto parts store
About 3/8 inch in diameter
I drilled a hole and installed it in a metal brace that’s under the seat cover
It’s wired in line with the regular key switch
So you have to twist the ignition key to the start position AND hold this button down at the same time to run the starter
I’ve seen one where they used the cruise control button
I’ve seen one where they used the windshield squirter button
And a couple of my old 18 wheelers had a low oil pressure shutdown that killed the engine if the oil pressure dropped too low
To start the engine you held down the low oil shutdown over ride button while running the starter and held it down till the pressure came up after the engine was cranked and idling
rrent
Round Rock Texas
Ronnie
Silverzdo
I’ve put a switch in the neutral safety switch line - purple wire on 70’s/80’s Chevy Camaros (possibly others) at bottom of steering column or the floor sifter. I just added a micro switch in a “super secret” location.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I got a set of these stickers on my 76
h3adbang3r14
Ohio
markus
k20
sbc 400 from 78 k30
My dad used a hidden headlight dimmer switch to cut\supply key voltage to the coil on his prostreet vega
jimlayhee
