Help!!! With getting main bearing to roll in
80BrownK10
Greenwood, SC
Nate
I rolled out my rear main bearing but can't seem to get the new one in. It hits the block. There .010 bearings like the crank was stamped. I don't have a mic but used my calipers to measure the leading edge of the bearing and it measures the same as the old.
I have all main caps loose what are some tricks here.
Only think that comes to mind is to taper that edge against the block so it will start but something tells me that's probably not a good idea:evillol:.
Rickf
Grafton NH
1974, 1954 & a 1937
I'm not sure if loosening every bolt that holds the crank in place will help, (from the balancer to transmission)
80BrownK10
Greenwood, SC
Nate
I have done that. So do you think I need to snug them all back up? They were snug at first and it didn't help. I'm my mind it I thought would allow some tiny, tiny amount of droop. But it seems to not have mattered
yevgenievich
Place
Name
Year
Model
Size
Are you doing them one at the time with all caps slightly loose? Few months ago I did same procedure on my elco. Would just lay oiled half on the journal and it would roll in.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I've done this several times with no problems.... hmm.
80BrownK10
Greenwood, SC
Nate
Yes that's what I tried.
80BrownK10
Greenwood, SC
Nate
Yes that's what I
I have found a fourm where a guy had the same problem, he eventually got it, never said how he got it though.
Maybe my cotter pin that keeps slipping is too small to roll it in effectively?
Rickf
Grafton NH
1974, 1954 & a 1937
If you have a standard transmission maybe the input shaft is holding the crank up, if an automatic maybe it's the torque converter/flexplate.
80BrownK10
Greenwood, SC
Nate
Success!! I even went as far as loosening the flex plate bolts.
I kept looking closely and noticed it was the thrust side of the bearing that was hitting the block. It was the inward side. I have been dinking around for hours with this think. About six blows on a counter weight on the crank with my small dead low and it moved the crank back the thousand of an inch or so that I needed. I was able to start it by hand then roll it in with the cotter pin. I was starting to have visions of having to pull this motor to fix this:oops::rolleyes:
idahovette
Weiser Idaho
Perry
K20-K10
Ata boy Nate.....whiskey or beer always helps!!! Glad you got it
QBuff02
Central IL
Quincy
This is correct, when most main bearings have wear the thrust bearing is worn as well. Generally a flat blade screw driver or small prybar used to pry between a crankshaft counterweight and the main webbing on the block is all that is needed to move the crank forward enough to get the new bearing in.
80BrownK10
Greenwood, SC
Nate
I tried this but couldn't get the prybar I had in hand in and was also worried about what I was prying against. Good tip , and hope this will help others in future.
2manysquares2care
