Help with Gauges
carlyneedham97
US
Carly
I have a 77 k10 that I'm in the process of restoring. Im having issues with the gauges. When I turn the key on, the p/s turn indicator illuminates and stays lit. All bulbs are working properly. When I turn on the hazards, all of the back lit bulbs for the cluster begin to blink. Does anyone know the locations of grounds for the gauges besides the ones on the radiator support??
Sent from my SM-G960U using Tapatalk
4WDKC
Southern Florida
Kacy
You can ground them anywhere that is metal.. infact you should probably add a few extras I know we did on my corvette.
carlyneedham97
US
Carly
Thank you [emoji849] I'm looking for the ground wires from the cluster and if/ where they may ground other than the headlight harness
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I may be way off, but I had a bad ground up above my hood latch pull in the cab, way up there under the dash high in the kick panel area. Chased that for a bit.
Fireman605
Lawrenceburg ky
Chuck
k20
Be sure and check the little ground clips inside all the light sockets to make sure they are in tact. We just figured this out this morning on our 85 project and it cured all our problems. We had a socket with a broken ground clip
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
1985c20
Torrington, CT
Chuck
I don't think its a gauge cluster ground issue. Its a ground at one of the 4 turn signals. Every time I have had a turn signal indicator light come on steady like that its a bad ground at one of the lights. And the back lighting could be blinking because its back feeding through the parking light circuit.
Tanaga
Palmer, AK
Dave
6.2 diesel
Is there a ground wire screwed to the frame at each turn signal? I don’t recall seeing one on my trucks.
The ground for the cluster is a single black ground wire connected to a post near the top of the emergency brake assembly. If its missing or loose the gauges will "find" ground through various other sources.
cahillasher76
