Help with 85 wire harness on engine swap?
JustJohn
Greenville
I just got this thing from someone who couldn't finish the project and I'm chasing some basic issues from an engine swap (stock 350 to 454).
First thing is brake lights, I checked back to front and came through the firewall to find connectors with their missing mates. Probably why I don't have AC controls or cluster lights too... Can anyone help me ID these connectors and where their mates might be?
I know what one of the connectors is for (the easiest one). The connector shown below is the split/splice point for the A/C compressor. A light green lead comes through the firewall from the HVAC control panel, it goes to that connector and splits off and heads over to the low pressure control switch on the receiver. It exits the control switch as a dark green and is supposed to go back to that connector and enter on the other side. Problem is I can't see that dark green lead alongside the pair of light greens. The red arrow shows where it is meant to go:
Here is the plug with both sides wired up:
JustJohn
Greenville
Thanks, that gets me a start - no AC compressor at the moment. Power to the brake lights is the big one. I'd prefer to wire it back like the factory had it.
Power to the brake lights:
Normally, I would say first check the fuse. But if that fuse was blown you would also not have parking lights (or under dash courtesy lights) and you didn't mention those being out.
So, assuming the fuse is good, I would start ringing this circuit out at the brake light switch - it is easy to access and simple to test.
Brake light circuit is hot at all times regardless of ignition switch position.
Go under the dash and locate the brake light switch (not the e-brake warning switch):
The orange wire should be hot at all times. Check it for 12 VDC.
If you see power on the orange, test the switch.
Push down on the brake pedal and, while holding it down, check for voltage at the white lead.
If you have 12 VDC on the white, you have proven the circuit all the way up to the directional switch.
Do you have directionals but not brake lights? If so there is a problem within the directional switch. Let us know and someone will help.
JustJohn
Greenville
Thanks! I've actually gotten my meter out previously and traced no power to the orange wire, continuity at the brake light ground wire. I followed it into the engine bay and it doesn't seem to be plugged in to anything. (maybe)
Now that I re-read your response, I see I might be looking at the directional switch. I do have a turn signal on one side and marker lights.
Boone83K10
Boone, NC
Benjamin
attachment.php
middle connector is to plug into a 700r4. it goes down to the driver side of transmission.
top connector is EGR bleed solenoid connector.
bottom connector is (I'll think of it soon)
attachment.php
4 prong connector with green is your fuel tank selector valve connector
oval shaped connector is your knock sensor
chengny got the third one.
JustJohn
Greenville
I continue to be impressed...
Since it has a 454 and TH400 transmission, I think most of those are now moot.
I didn't realize there were dual tanks - the gauge seems to be working but I guess no idea what information I'm getting. That one at least is a candidate for finding its mate.
Other than that I think I now have a few days worth of effort getting a new signal switch and stalk installed. That will get me street legal enough to drive it to work.
Boone83K10
Boone, NC
Benjamin
I made a boo boo. The green 4 prong is not fuel selector connector. It would be 5 prong if it was...sorry
Sent from my SM-G920V using Tapatalk
Boone83K10
Boone, NC
Benjamin
The 4 prong is the ESC distributor plug. Throw it away, along with the knock sensor. I cant put my finger on that red connector. It is related to the entire harness in the pic. The white 700r4 is connected to the vacuum switch located at the 10 o clock area of the brake booster. The egr bleed solenoid connector is tied into that along with that red connector which I cant think of what it is. If you have a TH400, all of it can come out.
Back to the brake lights.
You say this:
Sounds as if you're confusing two different circuits.
First. The orange wire that goes to the switch under the dash is power to the brake lights - those are the lights that others see when you step on the brakes. And if there is no voltage on that orange wire, don't order a new directional switch yet. You have a problem somewhere between the battery/fuse block and the brake pedal switch. That is actually good news. Changing the directional switch is a pain in the ass and should only be done if everything else checks out.
Second. The lead that goes through the firewall and terminates in the engine compartment is for the brake failure warning lamp on the dash. It should be tan and connects to the single male spade terminal on the wire mounted to the frame as shown:
On the other side of the bracket/connector, the wire goes to a switch in the BPC (brake proportioning compensating) valve.
If a major loss of hydraulic pressure occurs in the braking system the switch closes and grounds that lead. That ground will illuminate the brake lamp in the instrument panel. BTW - the same dash lamp is used to indicate when the e-brake is engaged - but through a separate switch mounted on the parking brake engaging mechanism.
Back to the brake lights - and BTW, disregard what I said above about the courtesy and parking lights. They are not on the same fuse/circuit as the brake lights. The only other thing on the same circuit as the brake lights is the hazards lights.
Do you have hazard flashers? If the brake lights and emergency flashers are out, check the STOP-HAZ. It's the 3rd fuse up from the directional flasher on the main fuse block:
If the fuse looks good, pull it and test for voltage at the line side of the socket. That should be the RH side looking forward. But check both sides, the wiring diagrams are not always perfect.
If there is no voltage at the STOP-HAZ fuse socket, you will next need to check the fusible links. Start at the firewall junction block.
See if there is power into and out of the JB. If there is power at the RH stud (looking aft), check the fusible link. It's supposed to be obvious when they are burnt but do not always show a failure. Pierce the insulation where shown and check for voltage there.
If there is no power on the JB'S LH stud, there is another fusible link down near the starter solenoid that you will need to check.
JustJohn
Greenville
Thanks - I'll chase it down this weekend.
Incidentally, I do have hazard lights but the switch is screwed up. Easy to turn on, hard to turn off. There don't *appear* to be hacked up connections but I'm just getting into it.
If you do have hazard flashers, I would double check the orange wire at the brake lights switch for voltage. That 140 orange circuit is probably the simplest wiring in the truck.
Out of the STOP-HAZ fuse and to a splice. Coming out of the splice, one leg goes to the hazard flasher and the other goes to the brake light switch on the pedal. That's the entire circuit.
JustJohn
Greenville
Thank you for detailing this out so well. I am a mechanical engineer and typically run away from electrical problems.
I have brake lights now! I was confusing the low pressure switch with the stop light switch and was able to confirm the circuit had power. Continuity was good between all the grounds and it did turn out to be the turn signal switch. I had already ordered an OE unit and had it ready to put in. Maybe I got lucky but the job wasn't too bad.
The only thing not quite right is the travel on the switch cam. The signal lever doesn't quite press down far enough to lock the left turn. It can be held down to function though.
Also gave the brakes a real pressure bleed. They still feel like truck brakes but much better than the only other GM truck brakes I've worked on, a 96 Tahoe. Mush.
goodwrenchca
