Help, truck tries to start when I connect the battery
Blazin74
Sacramento
Erik
Blazer
1974 blazer sbc 350, mostly stock
Ok.... so I replaced my column from a tilt, to a non tilt. (Old one was done)
Rebuilt the non tilt and replaced the old started switch and parking/ neutral switch. Also added electrical grease on the plugs.
Went to connect the battery, and the sucker tries to crack over. With no key in the truck!
So I go right to the ignition switch, to inspect it. A purple wire previously poped out, and I thought I had to it on the right slot. I might not of. Does anyone know where this purple wire goes on the ignition switch?
tkleonard71
