Help please truck will not start
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Help 87 Silverado 5.7 will not start. Replaced cap, rotor, coil and ignition module and its getting good fuel spray and spark. I'm at a loss I've checked fuses and still nothing :(
Georgeb
Wisconsin
George
K10 Burb Z71
Is your no start condition new. Did this happen after the ignition parts change?
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
No it started before I changed and the cap and rotor button looked a little rough but I got it to start and drive home and when I went to change to reverse it shut off and wouldn't start again doing the same thing it was before
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Take your cap off and inspect everything to make sure everything is sitting right, then redo your plug wires just incase. I wanna guess the firing order is off
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
I'll check everything again I didn't change firing order and it's been running perfect until today
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Went out this evening and left the truck on the battery charger and it tried to start so I pressed the gas down a little bit and it started up and ran and had what looked like a lot of fuel smoke coming out of the exhaust upon startup maybe where it had tried flooding out from not starting?
78silverado
