Help! My coolant temp heats up fast in idle or slow-moving traffic (around 210F+) then decreases when I start driving (around 170F-190)
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Water pump or fan clutch
Does the fan turn freely when the engine is cold? Or does it have a bit of resistance.
Broken85
Cumberland, NJ
A
If the fan keeps spinning after you shut off the truck, then (as stated above) bad clutch.
75gmck25
Northern Virginia
Bruce
Check the fan and shroud with the engine off. Is the shroud in place? What type of fan?
If it’s a stock mechanical fan (no clutch), the belt should be tight and the fan should not move when you push on it. It is always coupled to engine speed.
If it has a flex fan, throw it away and find a stock metal fan.
If it has a fan clutch behind the metal fan, the fan should move when you push it (engine off), but have moderate resistance. Then start up the truck, let it run a few minutes, and shut it down. Now the cold fan clutch should have distributed the fluid and the fan should move freely when you push on it (engine off).
Start up the truck with the radiator cap off, and look down into the radiator where the heater hose connects. If you see water gushing into the radiator, the water pump is moving water and working.
Fitz
Washington, OK.
Don
K-10
454/F60/465/205/FF14
Most likely a worn out fan clutch. I use the Hayden 2797 Severe Duty fan clutch on all of my trucks. The severe duty locks up sooner. And free wheels later than the standard duty, or heavy duty ones. Yes, it will make more noise. I would rather have a fan making more noise, pulling more air. Than one free wheeling and not pulling air through the radiator when it needs to be doing just that. Along with the 7 blade G.M. fan blade, or aftermarket one. Make sure to also use a fan shroud to "funnel' the incoming air across the radiator. Hope that helps. Semper Fi. OUT!!!!!
59840Surfer
Montana
Joe
I tried the Hayden HD and my gas mileage got a big 3MPG hit beside the intense roaring.
I ultimately went to the dual electric fans and wired them up like my '05 GM trucks --- low voltage and high voltage (6V v 12V) and got my mileage back PLUS!
FTR ---> Newer GMs with dual fans, use a Series/Parallel relay system that gives 2-speeds to the fans.
If you're tricky and know how to use a pair of diodes, you can get 3-speeds!
Back to topic --- the Hayden is a lot of overkill IMO.
cadillac_al
Maine
Alan
It's always nice to have a new fan clutch. If that doesn't fix it then I think it is a radiator flow problem. I have a bad fan clutch and my truck only overheats in high gear. It doesn't overheat at slow speeds. When it starts getting hot I put it in 2nd gear and drive slower and I can watch the gauge go down. High gear really puts a load on the engine.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
First, 210 at idle isn’t terrible. If that’s as hot as it gets, I’d say you’re trying to fix a problem that really isn’t there. Make sure the fan clutch works as it should, and the shroud fits well.
You can easily test the fan clutch, throw a heavy blanket over the front of the grill (make sure it won’t get wrapped up in the fan!!) start the engine, and rev and hold at around 2500 rpm. If everything is working as it should, as the engine warms up you should notice a distinct roar from the fan, with a noticeable increase in airflow. Once you hear that, remove the blanket. As the engine cools, the roar and airflow should decrease.
Just don’t overheat the engine!!
82jimmy
