Nasty-LSX
TogetherforeverCovid19
- Nov 22, 2014
- HOUSTON TX
- Mi Hung Lo
- c10/k10/k20
- LSX
1985 k20. 350/400
Long story short, I put a new intake on last year. The truck constantly ran at 210 anything over 55/and above MPH. 35/50 MPH I run like 200 deg.
I NEVER had this problem before intake swap. Here's the deal. I went to my local auto parts and ask for a factory thermostat. I was told and given a 195. That was factory he said. I can hear my valves clatter at 210. All this time I been thinking it was my water pump, Reverse flow
or thermostat. So I figure I start with one thing at a time. I pulled the radiator cap off and could hardly see water flow. Even when it was 200+ degrees. I thought this was because my radiator is huge, its out of a 1999 suburban 454 2500. Anyways, I pull the Tstat and BINGO, I have water flow, it even takes forever to heat up now. With this radiator it wont heat up at all while im moving. If im in traffic I can run one fan and it stays at 180 degrees. With 2 fans, it runs to cool.
here it is in traffic with one fan going. NO T-STAT
here it is on the freeway at 70MPH with no fans going. NO T-STAT
Here is my radiator setup.
