Help Identifying engine elements
Jacksonrobinson
Cleveland, TN
Jackson
Hello, new C10 owner, and I'm trying to do some engine clean-up. I need help identifying two engine elements, that both seem to be pulling vacuum. Please let me know what they are and if and where they need to pull vacuum from. I couldn't seem to find them on the vacuum diagram. I've also included my C10's vacuum diagram if it helps.
1980 Chevy C10 305 TBI
Thanks for your help.
matt4426
NE Ohio
K35
The thing in the first picture is the vacuum reservoir for the AC unit. The dampers are vacuum actuated. Not sure about the 2nd picture. Maybe vacuum switch/sensor for transmission?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Do you have a turbo 400 trans.
Jacksonrobinson
Cleveland, TN
Jackson
Ok thank you, do you know if the AC Vacuum reservoir needs port or manifold vacuum?
saltdog
US
K20 Suburban
Second pic is the torque converter lockup switch, lower right in the diagram pic 3
WaterboyCrewCab
