smurph20
- Jul 13, 2011
- Clyde, Arkansas 72717
- Brad
- K20
- 350/SM465/NP208/4.10's
I bought one last year from LMC. Right now all the electricity has to go from the battery thru your headlight switch and then to the headlights. The new harness then has the power go from your battery directly to the headlights. My switch is much cooler now- and I'm running 100 watt H4 high beams.
The new harness needs to be wired to the + of the battery and then to a nice ground. The OEM connectors that plug into the headlights are disconnected. One of them (*I have a single headlight system, dual would be similar) then gets plugged into the new harness. This provides signals for low beam and high beam to turn on a relay that sends power directly from the battery. Even if I had the stock headlights they would be brighter as there is a voltage drop thru the old OEM wiring and then thru all the connectors and the headlight switch.
Something you might want to consider anyway. $30 at LMC or I've heard there are other places also.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=72
I got a similar harness form Painless wiring for my S-10 and I have loved it ever since I need to get another one for my square or just rob the one off my S-10 since its down for awhile.
