78chev
- Feb 15, 2024
- Stewartsville, NJ
- Sean
- C10
Hi everyone! I have a 1978 Chevy C/10 Stepside that has a souped up 250 inline 6 with a cam and 2 4-Bbl carbs. For some reason, the flywheel bolts keep coming loose. I have not worked on it myself, but the shop that has tightened the bolts and it happened again. After that, they replaced the bolts and used red loctite. It has come loose a third time now and not sure what is causing it. The mechanic who specializes in classics has no idea what is causing it to happen. Has this issue happened to any of you guys? If so, what was the fix? The transmission is a straight-tooth.
