Hello, New Members Here and Saying Help
Shoeless
Albuquerque
Marcos
350 small block
Welcome!
What's not "running right"?
As far as running goes, the steering wheel has a lot of play too and turn signal seems broken, the emergency brake doesn’t even seem connected, the pedal just hangs there, the dashboard is useless and only battery and oil pressure gauge seem to be working. Those are the first thing I have notice. The engine sounds good but I don’t know the make of it, so I am trying to find the serial number on it so I can ID and see what I can do to it.
Also thinking about rewiring the whole thing cause I see some wire have been eaten, and I think that is why the blinkers lights won’t work.
scrap--metal
MN
Calvin
'85, '81
K10, K20
Fix the turn signals and start driving that thing! Often times turn signal issues are caused by bad grounds, or incorrect bulbs. Check those easy things first.
Everything else you listed can be fixed with minimal down time while you're having fun putting around in it. The sooner you start driving it on the regular, the more you will love it.
jlyon1006
