Heater fan switch not working
73c20jim
Tombstone, AZ
Heater fuse was bad, replaced - upper upper, right right corner of fuse box.
New fan switch.
It works on off - low low fan - no problem like it's supposed to.
Car running, will not adjust fan.
Help, please.
:owned:
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
With the car running, does it only run on high? If so, your blower motor resistor is bad. It’s a five minute fix to replace it.
73c20jim
Tombstone, AZ
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
You may have multiple problems. The lower speeds are powered from the fester fuse, to the fan switch, they the various heater resistors, to the high blower relay thru a set of normally closed relay contacts, then to the fan motor. The high speed bypasses the blower resistor, the fan switch on high triggers the high blower relay do a different set of contacts and supplies direct battery voltage to the blower moter thru a separate fuse or fusible link. Put a test light on the blower motor power wire, see if you lose power on the other switch fan positions. Then do the same test on the resistor block. Hopefully you find one or more resistor block contacts that loses power. Then check for power at each blower switch wire. You should see one that has power anytime the key is on, and power at one wire for each speed. If not, the switch is your issue good luck
jlyon1006
