Headlights go on and off
rusted nuts
Pa.
Jeffrey
k20
4cly diesel
I would start putting things back the way they they should be 1st.
gmbellew
Kansas city
glen
suburban 1500
actually the only "old" part is the switch. with integral circuit breaker. I'd consider replacing it to see if that is it. or add relays to reduce load on the switch and see if that helps. do the highs and lows both do it?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Yes both high and low do it.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Also I have these lose wires coming out of the harness. The two yellow or maybe orange wires on drivers side the single one on passenger side. Anyone know what they go too?
82sbshortbed
Fuckemall!!
SE Texas
Doug
Thought one on passenger side might be horn. I ran my own horn with button on dash because I couldn't get it to work. Po put aftermarket steering wheel on too. Lol
Ellie Niner
Tucson, AZ
Tory
K10 Silverado
LE9 305
The way your headlights are going out, then coming back on looks exactly like an overloaded circuit breaker (and not a dead short). If you're running the stock bulbs those new headlights came with (they should be a 9006 in the low beam and 9005 in the high), they're well under the 15 amp rating of the circuit breaker inside the headlight switch. Thermal breakers almost start tripping at less than their rated amperage as they fail, so it's pretty likely... You could unplug one headlight and see if the other stays lit to test the theory. Do you know what that relay mounted to the header panel in your last photo is feeding?
Your dash lights, dope light, and courtesy light are on three different circuits that are unrelated to the headlight circuit. I'd just focus on the headlights, then start tackling the other stuff.
Auburn, Washington
It’s not the alternator.
Alt could be disconnected and the lights will burn until the battery is dead.
Hard to say with the “work” that’s been done in the past but a headlight switch is like $20 and half a beer job.
Auburn, Washington
Also NEVER EVER.... have I asked anyone to "hold my Beer"..........NEVER!!!.....lol......too many bad things could happen?
Man, you probably coined the term before it was actually a saying, over there in Idahoo! I’ve seen some of the old pics you’ve posted! Lol
Cheers!
82sbshortbed
Fuckemall!!
SE Texas
Doug
This truck doesn't happen to have an aftermarket relay kit on it for the headlights does it?
Yes it does but they were doing this before I pit it on. It allows all four to come on on high beams.
boomer23
