Headlight issues
nolv4ho
SW WA
Luke
350 tbi
So i bought an 87 GMC Suburban 2500. It's in really good shape over-all. My issue is that the headlights will come on fine for 10 minutes fine, but then will flash off and on and continue to do so. (on for a second, off for like 10 seconds) I just replaced the switch. Did not fix the issue, and while I was putting it back together, after I replaced the negative battery terminal the automatic door lock switches started immediately trying to lock and unlock( it does not move the locks, but theres something switching on and off). So now not only do i still have the headlight problem, I have an automatic door lock problem too. Any help is apprecitated.
WP29P4A
Nevada
Sierra Classic V1500
The first thing to check is always the grounds, easiest thing to check and correct before spending time trying to find a problem caused by bad or missing grounds.
SirRobyn0
Does it do it both on high and low? do the parking lights flash to? It could very well be a ground, but if it's just the headlights you might wanna think about the high / low changer as well.
nolv4ho
SW WA
Luke
350 tbi
It is just the headlights, Low beam or high beam too, if those are on. Conversely fog lights, dash lights stay steady on.
nolv4ho
SW WA
Luke
350 tbi
That's what I had read, and that's why I replaced the switch. Im pretty sure everything is stock. Where are the ground locations at that I should check?
WP29P4A
Nevada
There should be a ground for the headlights on the radiator support, there is also a ground for the dash, on the kick panel above the e-brake. Are the headlights standard incandescent bulbs? Not LED bulbs?
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
Does it have a command start or security system hiding up in the dash there?
Kinda weird for it to be good for 10 minutes then start doing stuff and also your door lock system is totally separate from the headlights so first thing came to my mind was a old command start or keyless entry system or alarm making thing do funny things
nolv4ho
SW WA
Luke
350 tbi
As for the locks, I don't see any evidence of a security system. The only aftermarket things are the trailer brake control, and the ****** cd stereo. If I remove the silver 30 amp fuse, the locks stop trying to switch. I replaced with new fuse. Still same issue. I can hear a clicking underneath the dash by the stereo, on about 5 second intervals. I also notice that the lock plunger moves slightly, however its not enough to lock or unlock. And if I manually try to flip the lock switch i get nothing on either door. Is there a relay under the dash I should try to replace?
timbritton
canada
Tim
1500sierra
I had this problem show up this weekend on my 82 GMC. I checked the headlight sockets . I found a fair amount of corrosion on both sockets and headlight prongs. I cleaned all four light prongs and sockets made sure they were snugly making contact and fixed the problem.
nolv4ho
SW WA
Luke
350 tbi
Headlights are FIXED. After spending hours checking grounds and voltages, adding dialectric grease, and having 2 other people look at it, I went and bought another Headlight Switch from NAPA. I think the brand is Echlin. Plugged it in and Voila, issue fixed. So Beware of OEM Brand from Cost Less Auto Parts. Not to be confused with OEM (Original Equipment Manufacturer), which is a separate discussion.
Side Note: The old headlight switch I pulled out looked brand new, so I think the seller tried fixing it, and put a faulty one in too. Shady mfer. So that's 2, faulty switches in a row.
Now I just have to fix the door issue that randomly popped up in this journey.
gmbellew
Kansas city
glen
suburban 1500
there is a relay for the power locks. seems that maybe it has gone bad.
mshawn
Malvern,Ar
Micah
c10,jimmy,k10
G
Factory fog lights?
Wolverine
Montana
C.A.
V20
I just bought and installed a new headlight switch that turned out faulty. It is increasingly difficult to purchase legit replacement parts, I would rather pay more than to have to do the job over...
ReefkoiC10
Colorado Springs
LS3
Reminds me of when one of the coils went bad on my LS, everyone says they hardly ever go bad must be a handful of other things wrong, but alas with electrical it could be anything really!
jlyon1006
