Headlight issue
73K20
Jake
So when I turn the headlights to bright I have only one working light and when I dim them they both come on but barely produce any light at all. Where do I need to start looking?
93 F250 3k in rebuilt 460
03 Xterra on 32s-stock for now
2005 Mustang-stock for now
Stroked
Beloit, Kansas
Jared
I would check and clean both headlight grounds first. They are on the radiator support by each headlight. Then check and clean the ground wire that runs from the radiator support to the battery.
Boone83K10
Boone, NC
Benjamin
ditto... clean the headlight prongs too for good measure.
73K20
Jake
Ok I checked the headlight grounds already but didn't check the one that runs to the battery so ill do that and see what happens.
73K20
Jake
I figured out the issue.
The ground wire from one of the switches I believe was broke off. Re ground it and now they work fine.
Stroked
Beloit, Kansas
Jared
Nice!
Good job!
brentjo
