curse
- Jun 9, 2018
- 49002 portage mi
- kyle
- c10
What could be a cause of numbers 2 and 8 header pipes not getting hot. All other cylinders are getting over 300 degrees. 2 and 8 are only making it to around 114 degrees. Compression in all cylinders is 135-145 psi. When I put the timing light clip on the spark plug wires it flashes so I assume it's getting spark. Plugs are new. Would a bent valve cause this? It does not run smooth.
