Headers and O2 sensor
1987R30
melbourne, fl
slash
R30
7.4l
I am considering putting headers on my 87 R30. Im looking for some experience with headers and the proper way to use an O2 sensor (what sensor, where to locate the sensor, and does it work well). Ive seen so many old trucks that run terrible. Mine runs perfectly and I dont want to mess it up. I still have a 3” factory Y pipe (single exhaust) that i want to convert to duals. So, who’s done it successfully?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
My autometer kit has a Bosch sensor and says they want it right after the manifold collector in the pipe. Or for headers, on the collector where all the pipes meet at the flange.
Have to mount them near vertical and as close to the manifold as possible, to keep condensation from building up and to heat the sensor up as fast as possible.
75gmck25
Northern Virginia
Bruce
If you have a heated sensor it can be farther down the pipe, away from the exhaust manifold, since it does not rely on engine heat to come to operating temperature. Simple two wire sensor needs to be as close as possible to the collector so it heats up quickly. All should be no more than about 30 degrees off vertical, to keep condensing moisture off the sensor.
Edelbrock
Earth
Grumba
K5 Blazer
Another resource might be to call custom exhaust shops. I'm sure they do that kind of work all the time, and would have some experience with what works best.
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
I assume you have a TBI unit? I think 87 is when they started rolling out, but not on everything.
gmbellew
Kansas city
glen
suburban 1500
If you're running good as is, and with the limitations of TBI, I'd just leave the exhaust manifolds on there. Headers wont add much from what I've read. Look at a new exhaust coming off the manifolds if you need a new exhaust system.
It should be a TBI 305,and a single wire O2 sensor,so it's going to have to stay fairly stock to run the TBI. That means no big cam,if you want to run headers the O2 sensor has to stay as close to the exhaust ports as you can keep it,and be in the collector. I'd convert to a 3 wire O2 sensor.
1987R30
melbourne, fl
slash
R30
7.4l
Leaning this way. I like the headers since i could do my own dual exhaust. But thinking i will just pay for 3” stainless duals from the manifolds back. Thanks
On a 454 I'd want headers. I was thinking you were 305.
Edelbrock
Earth
Grumba
K5 Blazer
From my understanding, headers will not improve the performance of the engine on their own. Headers only allow the potential for other performance upgrades to be utilized in the most effective way. For example:
(These numbers are not precise, they are just to illustrate a concept)
Stock engine with OEM manifolds - performance: 10.00 baseline
Stock engine with headers - performance: 10.05 No appreciable difference
Modified engine with OEM manifolds - performance: 13.20 very nice
Modified engine with headers - performance: 13.80 Ideal
The stock manifolds allow enough free flow of the exhaust to be sufficient for s stock engine, so increasing the flow wont help unless you increase the amount of engine performance to utilize that extra flow. For example, if you bored it way out or made it a stroker, modified for very high RPM, installed forced induction etc.
Its kinda like installing a speedometer that goes up to 500 MPH. If there are no other mods made to a car, then the upgraded speedometer is nice and fancy, but is not actually of any use.
I could be wrong, but that's my understanding of it.
Most manufacturers spend millions to get the more power and efficiency, so if its something really simple and easy to do - they would have already done it. The Mythbusters TV show did a lot of experiments on this kinda thing.
Obviously companies that manufacture headers will disagree and say that all engines will perform WAY better with their specific design of headers, and maybe they are correct. Or maybe they just want to sell headers.
1987R30
melbourne, fl
slash
R30
7.4l
Nice write up. Thank you. It all registers with me as truth
nice writup. Thank you. I’m gonna stick with my stock manifolds. They’re in great shape.
Now do I do 2.5” or 3”? Brian Harris at tbichips.com says 2.5” duals. AI says 2.5” for low end torque. The exhaust ports of the stock manifolds are 3”. What do ya’ll say?
gshill13
