HD or "normal" 3/4 rear leaf springs
r67northern
Louisiana
Leland
Suburban r20
Hi Everyone,
I'm going to fix the driver-side lean on my R20 and get the load height back up. I've got a choice of either the normal springs or the Hd springs:
http://www.sdtrucksprings.com/index...Y2tCRbmyziqV8QOY84tCpwiOurBzNNHxoCeuUQAvD_BwE
Is there an option code that I should be aware of that might say what the R20 has on it right now? It's 4:10 rear gear option, so it may have HD on it if they were ever a factory option.
Thanks for any input.
twinturbo427
Florida
Phil
Suburban
Do you have the option sticker in the glovebox?
twinturbo427
Florida
Phil
Suburban
The RPO code should be G50 HD or G51 extra capacity
Info From a website so verify elsewhere.
yevgenievich
Place
Name
Year
Model
Size
See how many leafs existing leaf pack has. There was an extra leaf on hd
r67northern
Louisiana
Leland
Suburban r20
Okay, thanks for the input. I went diggin, found option
YD6 : REAR SPRING, BASE EQUIPMENT
So if I go HD, then it won't be stock... but according to the websites, the HD springs have the same leaf count as the normal ones. I'll do a little more double checking, might go HD anyway, it's going to be asked to tow.
yevgenievich
Place
Name
Year
Model
Size
I remember seeing two options for my 3/4 burb, and it was actually different leaf count. But it might have been something different.
edit:
For 91 3/4 suburban it shows 5 and 7 leaf packs, but the 5 one is probably for a 1/2 ton
r67northern
Louisiana
Leland
Suburban r20
edit:
Right - I'm seeing the reduced leaf count option too - I'm thinking that's for a 1/2 ton as well.
Craig 85
Nashville, TN
454/TH-400/NP205
r67northern
Louisiana
Leland
Suburban r20
Thanks for the link, great resource. I had run across it before, totally slipped my mind it was there. I'll get the HD springs on it and put her to work.
blackmfcowboy
