Halo Ring lights
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
I'm in search of the halo ring headlights
I used to have some on another squarebody of mine (an 84), im wanting some green rings for my 79, and possibly a bow tie that would match ?
These:
But in green. I know you can easily Google them, but the more specific question I'm posing is, which ones aren't cheap Chinese junk that's gonna cause the truck to catch Fire?
John-Ryan
John-Ryan
V20
Vbb199
Salisbury NC
Vince
Try these guys out..
https://www.oraclelights.com/pages/oracle-halo-kits-by-vehicle
They are a company that specializes in all lighting, I used to work with them for their trade shows and the quality is top notch. I've used there products on a few trucks but not a square (yet lol).
I saw this.
It just says c10 truck, I'm thinking the beams on a round body are the same size as a 73-79/80
I'll go measure this round body outside and the 74 next to it
Vbb199
Salisbury NC
Vince
Yes. They're both 7" beams
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Those are the ones I was gonna go with. I remember looking at those like 10 years ago already lol. gm trucks from late 47(for sure, maybe earlier) and up are all the same 7 inchers.
Edit- other than the normal anomalies, like 60's gmcs with dual headlights and whatnot
Catbox
Peter
C20 Silverado Camper Special
Modern Jeep headlights will fit as well if you are not finding what you need in squarebody specific.
We have a set of H-4 stock Wrangler take-outs on my truck.
Vbb199
Salisbury NC
Vince
I want to note when I looked on Amazon for c10 halo lights, I found alot of jeep headlights.
Theyre the same diameter I assume ?
Vbb199
Salisbury NC
Vince
@Catbox
This was one
DOT Approved 7 Inch Round LED Headlight High Low Beam Compatible with Wrangler 97-2017 JK TJ LJ JKU Rubicon Sahara Hummer H1 H2, 2 PCS (Green Halo) https://a.co/d/hxlVknm
Catbox
Peter
Yes sir.
All 7 inch round will fit many different styles of vehicles.
My VW's use the same 7 inch lights the truck does as that was where the Jeep lights were originally destined to go.
But then we had a bulb go out on the truck and there they went after a plug adapter was sourced.
jlyon1006
