MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
RV cam should work real good in these engines.
I'm pretty sure they're 1.94 / 1.60 valve heads. RV cam and 1.72 / 1.50 valve heads would work even better. They might be 1.94 / 1.50 valves too which won't be to bad.
That's good for RV Cams. Everyone seems to want bigger valves and pay big bucks to get them put in. That's all fine and dandy for the upper rpm band and racing, but for low end torque and pull power, the smaller valves are better. This is why many truck heads have the small valves.
Leave the stock cam in, and change the exhaust valves to 1.7.....look out jack! works good on 4.3s too. TBI heads even wake the **** up.
Stock 1.94 intakes are fine, its the 2.02s that bring intake velocity down. SBC heads have always suffered in the exhaust area.
Have an update on my dad's truck. He did have an RV style cam installed a few years ago. He said it helped a bit, but wasn't too impressed.
About a week ago he had some Edelbrock E street aluminum heads installed. These were 64cc chambers which boosted the compression ratio by about a full point. The heads do have the .202 intake valves but they have pretty small intake runners that keep the velocity up and are good for low end torque. He also got rid of the stock exhaust manifolds and went with 2.5" ram horn exhaust manifolds. So far he loves it- but has put his 5th wheel trailer away for the winter. There will not be any towing testing done until this spring.
But with just running around he has noticed several things. He lives up in the mountains and parts of the road were he had to slow down a bit around a curve and then be faced with a long uphill area are better now. Before the truck had to downshift to 2nd then it would accelerate then with a shift to 3rd then it would barely accelerate. Now around the same corner at the same speed it just stays in 3rd and can accelerate up the hill with no problem.
Gas mileage is much improved. He has put on about 200 miles so far, and he hasn't had exact figures yet and is going out of his way to find any/all big hills to charge up but he said gas mileage has improved 40%. So instead of around 10 mpg he is now getting 14+.
I haven't driven it yet. In the next few weeks I should be down there and will hopefully drive it. If nothing else I'll take some pics of it. The truck is in great shape and I guess even the valve covers were painted to match the truck instead of chevy blue.
Sounds like that truck my benifit from th next step higher gear ratio...less stress on the engine means better all around performance...especially in that area.
Sadly he already went thru that once. It had .308 gears and he asked what I thought he should have. I said 4.10s. He then went out and had 3.73's installed.
But at least he is just running stock sized tires and not something larger.
Sounds like a tired bottom end. Was there ever a compression check done after the new heads went on?
Ahh, ok, i am going through too many threads at once here, getting confused.
Is Pop's truck the one with the 290 hp 350? I have always considered that more of a car engine, cammed for higher rpm performance. Cam duration is 222/222
most trucks are Around 190/195
higher cam duration, moves the useful torque up the RPM band.
