Man this is killin me!! I have had MANY of these old Dodge trucks/Ramchargers. Good luck with it, try to save the old girl. Can I ask how you got it and how much?
One of them I stabbed a GM HEI distributor and CCC carb system off a mid 80's GM, really made a huge difference in drivability.
Is a HEI plug n go?
This has some goofy capacitor lookin thing on the coil wire position on the dist cap. Never seen before. Doesn’t look stock. Like some spark booster r something.
Also interesting “mod” is aftermarket dual shocks were installed all 4 corners. The rears are just doubled up parallel with the OE shocks.
The fronts are mounted at about 30 deg to horizontal, on the front side of the axle.
They have no range of motion really if the springs compress. But would compress if the front axle slid forward. More like some sort of stabilizers I’ve never seen before.
No pics. Not home for the next few days
I don’t usually talk money, but since you asked, I think it was a deal. Local Craigslist add. $3500
Took a bit of a leap that it will run, and it does, so I think it was a good deal.
