Got a cast iron point type distributor to rebuild, questions.
t44e6
NH USA
Got a real nice cast iron SBC distributor on eBay, it is as installed in 60-61 Corvettes. I'd like to install it in my 1982 K-10 with a 350. I am assuming that the drive gear is the same on all SBC engines, and that if necessary I can put different springs on the advance weights to get the correct curve. Anything else to change or check? Where is a good source in addition to eBay to find NOS points, condensers, caps, rotors etc? Did the points or other parts change for later pre HEI units, and does anyone have a source for detailed info? Thanks!
Turbo4whl
Downingtown, PA
Wayne
Delco uniset points are an upfit to that early dizzy.
NM.
F1r3truck
