Good resource for 9+1 Rear Leaf Springs?
tpripps
Scandia, MN
Tyler
C30
I've found that not only is the passenger side leaf broken as I had originally thought, but now I've discovered that the driver's side is too. I was originally going to pull some springs off of a junked truck but I think they're probably going to be just as bad as the ones I have on it now. Does anybody know of a good resource for spring packs?
Junk Truck
Driver's side of my truck
Passenger side of my truck
AKguy
Alaska
Randy
K30 Crew Cab Silverado
Murphy’s Frame and Axle!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Don't give up too quick on the wrecking yard... you might even find a new set under a wrecked truck.
AKguy
Alaska
Randy
Was not bad and they were great to work with.
Those ones broke due to rust buildup between the leaves. Good used packs shouldn't be too hard to find if you want to keep it cheap.
77 K20
Montana
K20 5" lift
HT383 fuel injected
If you want new packs look at Rockauto. And we get a forum discount there. They offer several different brands. When I bought rear springs I chose Dayton- been around a long time.
tpripps
Scandia, MN
Tyler
C30
great to know about the discount. Thanks!
Craig 85
Nashville, TN
454/TH-400/NP205
I had a broken leaf both of my leaf packs. I had them rebuilt locally. I'm in California though, so I'm guessing my leaf quality was better to begin with.
rjshope2007
