Going sniper efi choke light
wildone454
wv
cody
when I go sniper 2 what will I need to do if I don’t want to run the oil pressure switch or the choke wire to make sure the choke light will stay off?
SquareRoot
Sniper eh.. :mexsmoke:
You can always unplug the oil pressure switch and choke light. Save the energy for the other things that's gonna pop up.
wildone454
wv
cody
if I get rid of the pressure switch will the light remain on the dash?
Do you have 2 oil pressure switches 1 by the distributor 1 by the oil filter? If so how many wires on the one by the oil filter?What year truck are we working on? Was it originally 454 if not,what engine was in it new?
wildone454
wv
cody
It’s 1983 truck was 454 swap previous owner cut the wires on bulk head I have put all new wires back in the buck head so it just like factory it’s ready to install pressure switch and the pressure sender I have already installed the pressure sender the one wire above the oil filter i was gna install the pressure switch up near the distributor and hook it up just like factory to my carb but I’m going with the sniper 2 system now I was wondering if I didn’t even install the pressure switch where o won’t need the wire for the choke heater if my light would stay on
wildone454
wv
cody
v6 originally
wildone454
wv
cody
On wire by the one at the oil filter
So how many wires went to the original O P. Switch by the filter and what are the colors? Okay you typed your last response while I was typing. Switch at OP should be 2 or 3 wire. Since the wires Aren't there,I can't tell you how to bypass. I think I'd just pull the bulb out of the dash.
canadak10
